  1. Is there a way to Save that process when Nero Reencodes the MPEG1 to MPEG2, because it takes me three hours to complete that process. and if I want to burn more than one copy of the same movie, it goes through the process again taking another three hours.
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Yes; just copy the first SVCD you have created.
    The Dutchman
  3. Banned
    Jun 2001
    UK
    On the burn menu, select the number of copies you want
  4. this doesn't answer your question (actually the earlier posts did), but you might want to use another encoder besides nero's plugin (like the TMPGenc program).
    In mine and probably most of the forum's opinion, TMPGenc does a MUCH better job of reencoding).
  5. Thanks for the replies, The earlier questions did answer my question. Sometimes you get so caught up in looking for a complicated answer that you don't even consider the simplest ones. Thank you guys very much. I will try the TEmpg I believe it was called. I love the Net.
