I need a little help. I have a DVD+R burner and have a 1:21 divx movie. I followed the newbie guide to convert it to a mpg vcd file and burn it to a CD-R. I extracted the audio and used TMPG to create the mpg output. Halfway or earlier through the movie the audio gets out of sync. I dont understand why. Also, shouldnt the movie fit on 1 80 Minute CD-R since I shaved off a couple of minutes. When I created the mpeg file is is 797 megs. Should I be burning this to DVD instead? Thanks for the feedback.
For sync problems with divx files you can rip the audio off with VirtDub and save as a uncompressed wav file....Use that wav as audio and the avi as video portion when encoding....
As far as fitting on 1 CDR ...people set here and tell ya that you can fit 800 mb on a 80 minute CDR.......I can't...I have fit 762 mb ....so far thats all I've got to fit....anything bigger becomes a coaster....but hey thats me : )
VHS to File Conversion Newbie
By gk_terato in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2011, 21:18 -
Conversion advice for a newbie
By darafat in forum Video ConversionReplies: 1Last Post: 20th May 2010, 01:17 -
Newbie conversion help
By chiller15 in forum Video ConversionReplies: 2Last Post: 7th Apr 2010, 07:41 -
Newbie problems: TS to Mpg conversion
By waehuun in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2008, 16:00 -
Very Newbie Conversion -- Vob to Avi
By dadada_999 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 12:51
