My mate downloaded spiderman, he put it on cd gave it to me. I went to convert it to vcd but when I did there was only about 50 odd seconds of sound right at the beginning. Anyone help with my problem?
I doubt anyone can help you unless you provide a great deal mor informations such as.
1) Spiderman on CD, what format is it in (mpeg, divx avi or what)
2) Does the original file play good on your PC
3) What steps did you use to convert it to VCD. There are many tools and techniques available for this, unless we know what you did we can't guess where you went wrong.
4) Have you tried following any of the gudes on this site (there are many). If so which one, if not take a look at the conversion guides under HOWTO Convert on the left of this page.
5) If still stuck come back and ask again remembering points 1-4 above
Good Luck -
All are very good questions.....
You'll get deferent answers depending on what you say....for examle...if the original file only has 50 sec of audio....we cant help...well answer would be to get a better copy...with audio....
So help us... help you -
Ok, slightly silly, assume divx do I.1) Spiderman on CD, what format is it in (mpeg, divx avi or what)
silly question to ask when the thread title is avi to vcd
Anyway, what I suggest is that that you use virtualdub to extract the audio to an uncompressed wav file and try again, using that wav as the audio input.
If you want to do a test encode with a short clip, I would also suggest using virtualdub to cut the 1st 5 mins or so from the start of the movie, extract the audio from that and encode. This way you are sure the audio matches the movie. Not sure how well TmpGenc source range feature works with respect to audio.
Anyway, give it a try.
Good luck -
I found out what the problem was, it was a software problem with the sound card, I have unistalled it and reinstalled it and everything seems to be fine now.
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
