I'm getting an All in Wonder 128 next week to play with, and I was wondering about some settings I have seen. The resolution for VCD is 352x240, and normally just one field is captured. However, AIW has a screen where you can select field A, Field B, Deinterlace and Both. The field options are obvious, but I would like to know what the Both, and Deinterlace is, and what is the difference between the two. Deinterlace is basically a 2:1 vertical reduction, where the one line from each fields are added together. Then, what is Both mode? The same as Deinterlace? Also, what method is used for adding the two fields? Or does the settings not work for x240 line capturing? The cubic mode is the best. If anybody knows, please share
SK
Results 1 to 1 of 1
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
Capture software for ATI HD Wonder 600 PCIe
By Spektre in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2011, 09:31 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
I can't get my ATI tv wonder PCI 650 to capture
By Onceler2 in forum Capturing and VCRReplies: 5Last Post: 28th Nov 2009, 10:47 -
Ati 550 pro best capture software...
By RE*S.T.A.R.S.*2 in forum Capturing and VCRReplies: 13Last Post: 14th Jun 2007, 18:46
