i was recently advised 2 buy an m-peg card for my pc for the pupose of watching my movies .
I have since bought 1 and found out for a start i cant watch divx or avi files which i didnt know and when i watch my vcd's svcds every few minutes or so the picture and sound pause for a half a second or so which is annoying it also a little blocky at times .
I thought my computer might have been to slow so i upgraded to a 1.8 ghz xp but still no luck ,,,the m-peg card runs through my graphics card which is an ati rage do u think it is this that needs upgrading . I dont want to fork out again if i dont have to . If it is can someone reccomend me a graphics card ( i dont play games just watch movies ) thank u a lot for all of your help and keep up the good work .
Unless your MPEG card has extra features such as a TV output then you should no longer require it to watch DVDs.
Most PCs have the raw CPU power to provide MPEG decompression without extra hardware. All you require is a DVD-ROM drive and a suitable software DVD player such as PowerDVD or WinDVD.
If you want to watch DivX then you must download the relevant codecs. You can find them by following the links below.
http://www.divx-digest.com/software/divxcodec.html
http://www.divx.com/divx/
You do not have to buy a new graphics card or anything else.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 7th Oct 2011, 23:01 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51
