There is a real challenge for the "pro" on video editing:
I got a divx movie (Tom@Jerry) with the following parameters:
Frames/sec - 23.976
Video codec - div3
Audio sample rate - 48000s/sec
bits per sample - 0
channels - 2
bitrate - 140168
I can watch it without problems with any player, but I'm trying to convert it to SVCD, - well I cannot do it with any proggie.
On Prem6 it looks that it has no Audio at all. Ulead video studio 6 gives me sound for 50 minutes from 82 minutes of the movie ad then stops. No syncro at all..
I even cannot deinterlace audio/video...no use.
I don't know the div3 codec...and I'll be very thankful for helping or any ideas... maybe to record the audio separate (How to do it? with which proggie ?)...or any other idea... PLEASE
TIA
Well I got a Scooby Doo SVCD Screener AVi that will not encode into any VCD or SVCD that NERO will reconize, Her was my solution
Play Scooby AVI through my Utobia MPEG2 output card over to my Panasonic DVD recorder DMR E-20, Record it on Ram discs at 9000 bitrate, no picture loss, play ram disc back over to my computers MPEG2 Capture card and captured it at 480x480 at 3000 bitrate, now I can burn the MPEG no problem and I can not tell any difference from the original AVI and the new MPEG2, If you have a capture card, TV out and a SVHS machine or HI8mm Camcorder you could do the same thing with very little loss of picture quality. -
Follow the guide below. The audio is probably encoded using a codec unsupported by your encoding software - the guide shows you how to decompress it out to an uncompressed PCM WAV file.
http://www.vcdhelp.com/divxtovcd.htm#audio
http://www.vcdhelp.com/tmpgencsvcd.htm -
Thats probly going to tell ya to rip the audio off with VirtDub and save as a uncompressed wav file....Use that wav as audio and the avi as video portion when encoding....this also works on sync problems....
Div3 = DivX 3.11 Alpha Low motion
Vdub
Audio > Full processing more
Audio > Conversion > 44.1Khz
SAVE WAV
strange DVD - various screen ratios in movie
By Heliooos in forum DVD RippingReplies: 7Last Post: 19th Jul 2011, 08:47 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
I have a really strange problem with movie files
By Jimbo1 in forum Newbie / General discussionsReplies: 6Last Post: 14th Mar 2011, 07:53 -
REALLY STRANGE RARE THING: MPG video CHANGED after file transfer or copy
By xboxsold in forum Newbie / General discussionsReplies: 21Last Post: 1st Feb 2011, 10:28 -
Strange Ghosts on mp4 movie
By PistolSlap in forum Software PlayingReplies: 9Last Post: 22nd Apr 2010, 11:43
