evil: I finally have been able to convert a Divx movie to VCD format, with the movie on 2 disks. Multiple times during the movie the motion seems to jerk and the audio seems to speed up or lag behind. The character's lips often move and then the words are heard or vise versa. Thanks for any help you can offer.
Results 1 to 11 of 11
Have you followed the instructions in the divx to vcd tutorial found on this site? Regarding extracting audio with virtualDub? Try it.
Having same prob, especially in dark passages. And, yes, I extracted with virtualdub. I think thats the problem. If I burn directly with win-on-cd its synchrone (but the resolution is bad
I belive that I used virtual dub correctly, it almost seems as if the video is slowing up or speeding up during the burning. After this happnes it does catch up with itself, so might try burning at a slower speed.
8) Burning speed is irrelevant. When u burn, u copy a bytestream. The burning speed has no influence on the contence (Exception: The software itself decodes). I think tmpgenc creates a variable frame rate or something like that, to reduce size, that most DVD players cant handle properly.
It could be your DVD player. Is there another player you could try the movie or? How about a DVD drive in your comp /w a DVD program? Also what media are you using? Quality? Have you read the DVD player compatibility list entry for your player?
It may be a error correction problem of my player.
After experimenting one day, there is only one solution: Create a SVCD. No sync problems with those on my DVD player and the images are much better too 8) :P
. And one more tip: Use rewritables till u are satisfied
and make a disc copy then
. And you can create one mpg2 file and burn the CD's one after the over with WinOnCD
(better than Nero, cause it can cut). U don't have that? Oh.
Ever heard of EDonkey
(If u have no flatrate, forget that)? Anyway, u sure know it illegal to download hacked software
With my apex player I've had the same problem when I encode in ntscfilm 23.976. Just re-encode to 29.97. This has worked out great for me with alot of divx movies. Also leave your audio at 44mhz and 224 bitrate.
I've never seen anyone use so many emotes without trying to be intentionally analOriginally Posted by JimSpade
in other words, no Qwikster.
By cal_tony in forum Latest Video NewsReplies: 7Last Post: 10th Oct 2011, 18:00 -
Working With Chinese Words
By W0rm in forum SubtitleReplies: 2Last Post: 3rd Feb 2009, 21:27 -
slightly OT: Words to live by
By terryj in forum MacReplies: 0Last Post: 17th Jun 2008, 14:11 -
... famous last words ...
By Midzuki in forum TestReplies: 0Last Post: 26th Jan 2008, 19:51 -
biblical words
By vin4evr in forum EditingReplies: 9Last Post: 18th Jan 2008, 12:16
