if you are capturing in lossless AVI, and you don't get any dropped frames regardless of which program you use to capture with (eg virtualdub and virtualvcr), does that mean the quality of the avi file will be the same? As both programs are using the same drivers, and both programs are not dropping frames, I started thinking that perhaps it may be an option to use a simpler program than virtualdub for the capture process ... and just use virtualdub for post processing if required ... is this logic flawed? Thanks.
Results 1 to 1 of 1
Best way to provide video content for waiting room?
By macgyver58 in forum Newbie / General discussionsReplies: 47Last Post: 8th Feb 2015, 06:06 -
How to upload files to videohelp and provide correct links ?
By vhelp in forum FeedbackReplies: 21Last Post: 9th Feb 2009, 12:06 -
Will my stand alone DVD Player provide 5.1 for my surround sound?
By dc01039 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2008, 03:14 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20
