Can anyone else here figure out why the VCD created with the following XML skips to the smenu-1 rather than playing smenu-0 with introaud audio? I'm racking my brain and can't figure it out! Someone please help!
<?xml version="1.0" ?>
<!DOCTYPE videocd (View Source for full doctype...)>
- <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0">
- <info>
<album-id>VENUS_VCD</album-id>
<volume-count>1</volume-count>
<volume-number>1</volume-number>
<restriction>0</restriction>
</info>
- <pvd>
<volume-id>VENUS_VCD</volume-id>
<system-id>CD-RTOS CD-BRIDGE</system-id>
<application-id>CDI/CDI_VCD.APP;1</application-id>
<preparer-id>vcdxbuild (GNU VCDImager) 0.7.12</preparer-id>
<publisher-id>TSCV084R1</publisher-id>
</pvd>
- <filesystem>
- <folder>
<name>CDI</name>
- <file src="D:\Program Files\TSCV\CDI\cdi_imag.rtf" format="mixed">
<name>CDI_IMAG.RTF</name>
</file>
- <file src="D:\Program Files\TSCV\CDI\cdi_text.fnt" format="form1">
<name>CDI_TEXT.FNT</name>
</file>
- <file src="D:\Program Files\TSCV\CDI\cdi_vcd.app" format="form1">
<name>CDI_VCD.APP</name>
</file>
</folder>
- <folder>
<name>CD_COVER</name>
- <file src="F:\VCDs\Venus VCD\CD_COVER\CD_COVER.jpg" format="form1">
<name>CD_COVER.JPG</name>
</file>
</folder>
- <folder>
<name>EXTRA</name>
- <file src="F:\VCDs\Venus VCD\EXTRA\SOURCES.txt" format="form1">
<name>SOURCES.TXT</name>
</file>
</folder>
- <file src="F:\VCDs\README.txt" format="form1">
<name>README.TXT</name>
</file>
</filesystem>
- <segment-items>
<segment-item src="F:\VCDs\Venus VCD\mainmenu.mpg" id="menu-0" />
<segment-item src="F:\VCDs\Venus VCD\menu1.mpg" id="menu-1" />
<segment-item src="F:\VCDs\Venus VCD\menu2.mpg" id="menu-2" />
<segment-item src="F:\VCDs\Venus VCD\bliss.mpg" id="menu-5" />
<segment-item src="F:\VCDs\Venus VCD\menu3.mpg" id="menu-3" />
<segment-item src="F:\VCDs\Venus VCD\credits.mpg" id="menu-4" />
<segment-item src="F:\VCDs\Venus VCD\intro.mmd" id="introaud-1" />
<segment-item src="F:\VCDs\Venus VCD\bliss.mmd" id="blissaud-1" />
<segment-item src="F:\VCDs\Venus VCD\credits.mmd" id="creditsaud-1" />
</segment-items>
- <sequence-items>
- <sequence-item src="F:\VCDs\Venus VCD\1 - 1 - Bliss.mpg" id="sequence-1">
<entry id="entry1-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\1 - 2 - 1,000 Oceans.mpg" id="sequence-2">
<entry id="entry2-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\1 - 3 - Glory Of The 80s.mpg" id="sequence-3">
<entry id="entry3-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 1 - VH1 100 Greatest Women.mpg" id="sequence-4">
<entry id="entry4-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 2 - Late Show - Bliss.mpg" id="sequence-5">
<entry id="entry5-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 3 - Tonight Show - 1,000 Oceans.mpg" id="sequence-6">
<entry id="entry6-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 4 - KTLA Morning News - 1,000 Oceans.mpg" id="sequence-7">
<entry id="entry7-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 5 - Late Night - 1,000 Oceans.mpg" id="sequence-8">
<entry id="entry8-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 6 - Rosie O'Donnell Show - 1,000 Oceans.mpg" id="sequence-9">
<entry id="entry9-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 7 - Daily Show interview.mpg" id="sequence-10">
<entry id="entry10-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 8 - Later With Jools Holland - Suede.mpg" id="sequence-11">
<entry id="entry11-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 9 - Later With Jools Holland - Concertina.mpg" id="sequence-12">
<entry id="entry12-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\2 - 10 - SNL spoof of Tori Amos.mpg" id="sequence-13">
<entry id="entry13-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\3 - 1 - TV ads.mpg" id="sequence-14">
<entry id="entry14-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\3 - 2 - VH1 Women First.mpg" id="sequence-15">
<entry id="entry15-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\3 - 3 - MTV 1515.mpg" id="sequence-16">
<entry id="entry16-0">0.000</entry>
</sequence-item>
- <sequence-item src="F:\VCDs\Venus VCD\3 - 4 - Jones Beach - Tear In Your Hand.mpg" id="sequence-17">
<entry id="entry17-0">0.000</entry>
</sequence-item>
</sequence-items>
- <pbc>
- <selection id="smenu-0" rejected="false">
<bsn>1</bsn>
<prev ref="endlist" />
<next ref="selection-44" />
<return ref="endlist" />
<default ref="smenu-1" />
<timeout ref="selection-44" />
<wait>0</wait>
<loop jump-timing="immediate">1</loop>
<play-item ref="menu-0" />
<select ref="smenu-1" />
<select ref="smenu-2" />
<select ref="smenu-3" />
<select ref="smenu-4" />
<select ref="endlist" />
</selection>
- <selection id="selection-44" rejected="false">
<bsn>1</bsn>
<next ref="smenu-1" />
<wait>1</wait>
<loop jump-timing="immediate">7</loop>
<play-item ref="introaud-1" />
</selection>
- <selection id="smenu-1" rejected="false">
<bsn>1</bsn>
<prev ref="smenu-0" />
<next ref="selection-m1-0" />
<return ref="smenu-0" />
<default ref="selection-m1-0" />
<wait>-1</wait>
<loop jump-timing="delayed">1</loop>
<play-item ref="menu-1" />
<select ref="selection-m1-0" />
<select ref="selection-m2-0" />
<select ref="selection-m3-0" />
</selection>
- <selection id="smenu-2" rejected="false">
<bsn>01</bsn>
<next ref="selection-m4-0" />
<default ref="selection-m4-0" />
<wait>-1</wait>
<play-item ref="menu-2" />
<select ref="selection-m4-0" />
<select ref="selection-m5-0" />
<select ref="selection-m6-0" />
<select ref="selection-m7-0" />
<select ref="selection-m8-0" />
<select ref="selection-m9-0" />
<select ref="selection-m10-0" />
<select ref="selection-m11-0" />
<select ref="selection-m12-0" />
<select ref="selection-m13-0" />
<select ref="smenu-5" />
</selection>
- <selection id="smenu-5" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m13-0" />
<next ref="selection-45" />
<return ref="smenu-2" />
<default ref="smenu-5" />
<timeout ref="selection-45" />
<wait>0</wait>
<play-item ref="menu-5" />
</selection>
- <selection id="selection-45" rejected="false">
<bsn>1</bsn>
<next ref="smenu-2" />
<timeout ref="smenu-2" />
<wait>1</wait>
<play-item ref="blissaud-1" />
</selection>
- <selection id="smenu-3" rejected="false">
<bsn>1</bsn>
<next ref="selection-m14-0" />
<default ref="selection-m14-0" />
<wait>-1</wait>
<play-item ref="menu-3" />
<select ref="selection-m14-0" />
<select ref="selection-m15-0" />
<select ref="selection-m16-0" />
<select ref="selection-m17-0" />
</selection>
- <selection id="smenu-4" rejected="false">
<bsn>1</bsn>
<next ref="selection-46" />
<default ref="smenu-0" />
<timeout ref="selection-46" />
<wait>0</wait>
<play-item ref="menu-4" />
</selection>
- <selection id="selection-46" rejected="false">
<bsn>1</bsn>
<next ref="smenu-0" />
<wait>1</wait>
<play-item ref="creditsaud-1" />
</selection>
- <selection id="selection-m1-0" rejected="false">
<bsn>1</bsn>
<prev ref="smenu-1" />
<next ref="selection-m2-0" />
<return ref="smenu-1" />
<timeout ref="selection-m2-0" />
<wait>1</wait>
<play-item ref="sequence-1" />
</selection>
- <selection id="selection-m2-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m1-0" />
<next ref="selection-m3-0" />
<default ref="selection-m2-0" />
<timeout ref="selection-m3-0" />
<wait>1</wait>
<play-item ref="sequence-2" />
</selection>
- <selection id="selection-m3-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m2-0" />
<default ref="selection-m3-0" />
<timeout ref="smenu-1" />
<wait>1</wait>
<play-item ref="sequence-3" />
</selection>
- <selection id="selection-m4-0" rejected="false">
<bsn>1</bsn>
<prev ref="smenu-2" />
<next ref="smenu-5" />
<timeout ref="selection-m5-0" />
<wait>1</wait>
<play-item ref="sequence-4" />
</selection>
- <selection id="selection-m5-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m4-0" />
<next ref="selection-m6-0" />
<default ref="selection-m5-0" />
<timeout ref="selection-m6-0" />
<wait>1</wait>
<play-item ref="sequence-5" />
</selection>
- <selection id="selection-m6-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m5-0" />
<next ref="selection-m7-0" />
<default ref="selection-m6-0" />
<timeout ref="selection-m7-0" />
<wait>1</wait>
<play-item ref="sequence-6" />
</selection>
- <selection id="selection-m7-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m6-0" />
<next ref="selection-m8-0" />
<default ref="selection-m7-0" />
<timeout ref="selection-m8-0" />
<wait>1</wait>
<play-item ref="sequence-7" />
</selection>
- <selection id="selection-m8-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m7-0" />
<next ref="selection-m9-0" />
<default ref="selection-m8-0" />
<timeout ref="selection-m9-0" />
<wait>1</wait>
<play-item ref="sequence-8" />
</selection>
- <selection id="selection-m9-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m8-0" />
<next ref="selection-m10-0" />
<default ref="selection-m9-0" />
<timeout ref="selection-m10-0" />
<wait>1</wait>
<play-item ref="sequence-9" />
</selection>
- <selection id="selection-m10-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m9-0" />
<next ref="selection-m11-0" />
<default ref="selection-m10-0" />
<timeout ref="selection-m11-0" />
<wait>1</wait>
<play-item ref="sequence-10" />
</selection>
- <selection id="selection-m11-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m10-0" />
<next ref="selection-m12-0" />
<default ref="selection-m11-0" />
<timeout ref="selection-m12-0" />
<wait>1</wait>
<play-item ref="sequence-11" />
</selection>
- <selection id="selection-m12-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m11-0" />
<next ref="selection-m13-0" />
<default ref="selection-m12-0" />
<timeout ref="selection-m13-0" />
<wait>1</wait>
<play-item ref="sequence-12" />
</selection>
- <selection id="selection-m13-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m12-0" />
<default ref="selection-m13-0" />
<timeout ref="smenu-5" />
<wait>1</wait>
<play-item ref="sequence-13" />
</selection>
- <selection id="selection-m14-0" rejected="false">
<bsn>1</bsn>
<prev ref="smenu-3" />
<next ref="selection-m15-0" />
<return ref="smenu-3" />
<timeout ref="selection-m15-0" />
<wait>1</wait>
<play-item ref="sequence-14" />
</selection>
- <selection id="selection-m15-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m14-0" />
<next ref="selection-m16-0" />
<default ref="selection-m15-0" />
<timeout ref="selection-m16-0" />
<wait>1</wait>
<play-item ref="sequence-15" />
</selection>
- <selection id="selection-m16-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m15-0" />
<next ref="selection-m17-0" />
<default ref="selection-m16-0" />
<timeout ref="selection-m17-0" />
<wait>1</wait>
<play-item ref="sequence-16" />
</selection>
- <selection id="selection-m17-0" rejected="false">
<bsn>1</bsn>
<prev ref="selection-m16-0" />
<next ref="smenu-3" />
<default ref="selection-m17-0" />
<timeout ref="smenu-3" />
<wait>1</wait>
<play-item ref="sequence-17" />
</selection>
<endlist id="endlist" rejected="false" />
</pbc>
</videocd>
