Hi! I am eagerly trying to capture from my newly installed ACTIONTEC firewire card with 3 ports. I have successfully installed everything BUT the problem is with the capturing. I see the VIDEO on the monitor BUT when I press CAPTURE it tells me that file created is CORRUPT. i am trying to capture MPEG because I want to make a VCD. I have tried various programs but the only one that is able to work with the card is ULEad VIDEO STUDIO. I have WIN98 installed, 10 gigs free, P3, 700MHZ.
Thanks for the time.
TSK2k
http://www.tsk2k.150m.com
PS>> i had made a post like this BEFORE but the problem is that my post didnt show up.
Just a suggestion:
capture with Ulead (if this works in your case) to the harddrive.
When the file is stored on the harddrive, close ulead, and open TMPGEnc, and encode the file to VCD Mpeg1 format.........The Dutchman
Problems Capturing from Vidoenics MX-1
By John Duvall in forum Capturing and VCRReplies: 0Last Post: 15th Dec 2010, 08:04 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 14:09 -
Capturing footage-problems ...
By perik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 7th Dec 2008, 18:11 -
Having problems capturing my 360 on my PC
By RR420 in forum Capturing and VCRReplies: 4Last Post: 23rd Feb 2008, 11:50 -
Sorry HV20 more capturing problems!
By rhodesy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th Jun 2007, 07:54
