is there a way to save a program so when you restart the computer meaning with the restart cd that it will still be there? or cant you? thanks for any help on this topic.
That makes no sense.
Restart cd?
Do you mean is their a way to save a program so that will still be their if you reformat? If so, no you cannot. You can burn essintial data to CD or put it on other media, however you will need to re-install the program after the re-format -
If you mean like a GHOST restore cd, then no. Not unless you put that program on another disc/partition. Ghost will blast the entire disc clean.
Xvid4PSP forcing restart of PC !!!!
By MOLA in forum Video ConversionReplies: 4Last Post: 17th Feb 2012, 04:05 -
HP Laptop wont restart
By jyeh74 in forum ComputerReplies: 5Last Post: 16th Dec 2011, 02:43 -
Question on WME9 and auto restart
By ml41782 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Jan 2011, 13:35 -
PC Doesn't Restart Properly
By bevills1 in forum ComputerReplies: 5Last Post: 5th Sep 2010, 22:20 -
Sudden restart
By alintatoc in forum ComputerReplies: 12Last Post: 25th Mar 2009, 11:49
