Hi,
I have managed to sucessfully convert several rm to avi files using tinra and guidence from GuiGuy (bless him!). These files work perfectly in Windows Media Player - sound, video in absolute sinc.![]()
However when I used Nero to burn to VCD everything slipped out of sinc. The video was far too fast and the sound was a bit quick on one file too. There is no problem with the avi file as it plays perfectly on my computer -is Nero the problem?
I understand that Nero coverts the .avi files to mpeg then to vcd... should I convert manually to mpeg (TMPGEnc ?) then burn ?
Any help or guidence would be gratefully appriciated !!
Cat
~*Love it or shove it*~
*~I don't know the solution, but I admire the problem~* -
Yes, Nero is rubbish at converting, use TMPGEncOriginally Posted by CatQuincey
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 20:21
