I Used DVD2AVI, then i put the .d2v and the .mpa on TMPGEnc but when i convert it doesnt have any sound! if i open the MPA file i can listen the sound, but when i convert theres no sound! What do i have to do? Any config in DVD2AVI?
Q: Is there no sound or is the sound just so low that you have to turn your sound up to be able to hear it. Acutally, if you hear the sound fine when listening to the .mpa then I'd say the DVD2AVI part went fine.
I ask this because I ended up bunging the settings in DVD2AVI and got this same thing. Until I figured it out, I was setting the sound filter on TMPGenc to increase the sound by something like 400%.
Wish I could remember what I did to fix it. Anyone else who knows DVD2AVI better that can help?
Double check your input for video and then your input for audio in TMPGenc. I've done that one a couple of times too.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Poor man's 5.1
By Haopengyou in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2010, 07:53 -
man kills girlfriend over 3-some
By deadrats in forum Off topicReplies: 3Last Post: 17th Mar 2010, 07:13 -
Remux Pirates of the Caribbean: Dead Man's Chest (2006) Problems
By TeeTee in forum Blu-ray RippingReplies: 4Last Post: 12th Feb 2009, 10:25 -
Man defies gravity...
By zoobie in forum Off topicReplies: 7Last Post: 8th Dec 2008, 21:22 -
Spider Man 3
By rbaroncpd in forum DVD RippingReplies: 18Last Post: 14th Nov 2007, 10:03
