hi again,been doing some converting with tmpgenc.when you go to advance tab,then source,i select full screen keep aspect aspect ratio if you want the film exactly as it is.i then leave aspect ratio as 1.1. i noticed after that the film encoded is slightly larger than the avi version.the resolution is 352x208.as avi,but when converted is 352x288.i wanted to leave as original as the pic deteriates when enlarge resolution. thanks
PAL VCDs have a native resolution of 352x288 and SVCDs 480x576. By loading the VCD template within TMPGEnc you are effectively telling the encoder to resize the video to fit the standards.
By unlocking the template you can encode to a non standard resolution such as 352x208 but it is unlikely to then play in your DVD player. -
I forget how to do it but you add black bars to fill the area making it the correct size for the vcd or svcd standard but retaining the original movie size. Anyone remember how to do this?Originally Posted by Dave B
Good luck!
reman
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 04:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 09:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 04:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 19:59 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 14:27
