Hi !
i know this question has been up before but what program is the best for capturing direct to MPEG2 under these conditions:
ASUS 6800 Deluxe capture card
CPU = 2 GHZ
RAM = 512 MB
HD = 80 GB
OS = XP
Berzerk...whatever you get pointed to, ascertain what your return / satifaction guarantee options are for what you buy. You may find that real time MPG2 capture is not as acceptable as you expect, compared to AVI capture and post processing. I have a WINTV PVR card that can't produce the results in real time even at 12 MB/s that I can get via an AVI.
maybe a was a little unclear of what i wanted.....I dont want to capture to AVI(To spaceconsuming) and i know there are programs that can convert captured video in real time, Ulead videostudio for example. But my question is....Is there any program out there that make this better then Videostudio(Convert to MPEG in realtime)
Soft base cannot record VBR (Variable Bit Rate), which means you have to use a CBR (constant bit rate). The other is that you can only capture audio at 44.1 kHz, which is good for CDs and VCDs which use this sample rate, but not DVD which uses 48 kHz.
Good Lucky
You could always get a WinTV-PVR 250 it come with ever thing you need MPEG editor and DVD authoring software and dosen't cost arm & leg to get. -
Cyberlink PowerVCRII
http://www.gocyberlink.com/english/products/product_main.jsp?ProdId=20
Avisynth MPEG2 to h264 Program Suggestions?
By VideoFanatic in forum RestorationReplies: 2Last Post: 14th Feb 2012, 18:33 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Best Program to Convert to MPEG2 to use in DVD SP 3
By nepgunes in forum MacReplies: 8Last Post: 12th Dec 2007, 15:15 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 19:55
