Hello all, thanks in advance for the replies.
Here is my problem. I have downloaded a DIVX/AVI using a 14.985 fps. When played thru Media Player, the video and audio are in sync from the start to the back.
I have tried several ways of making this into a VCD using tools such as TMPGENC and VIRTUALDUB following the well designed guides. First, I tired just taking the AVI into TMP, selecting the VCD-NTSC template and using the AVI as both video and audio source. 8 hours later (I have a P2 but I'll probably need a better laptop) I had a MPEG that when I played it in Player, the audio was ok in the beginning but gets steadily worse by the end of the movie. I then tried the extraction method of creating a WAV out of VD (about 660meg) and using it as the audio input source and keeping the AVI as video with a NTSC-VCD template. Another 8hrs later the same result happened on the MPEG. I also burned the MPEG to a VCD at about 4x just to see if it was perhaps the computer and the DVD player had the same problem.
Any help would be appreciated. Thanks to all.
Results 1 to 1 of 1
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
