Hi, any help would be appreciated.
I have managed to rip a dvd and copy to vcd (no problems) Next I tried to add chapters which I think I have done. I have 3 files on my desktop videocd, videocd.cue and videocd (bin) I have been following the newbie guide and when it comes to choosing your cd writer (settings - CDRAO) the screen is all one colour so I cant use any of the pull down menus. When I start VCD easy up I get the msg. No Cd writer/reader found or ASPI drivers problem. I use a Teac CDW 524E and have checked the web site for compatability and it's there. what next
Results 1 to 10 of 10
I have seen posts like this before, Maybe you should try updating your ASPI software, it comes with a tool (ASPICHK) to check that your present settings are also correct.
http://www.adaptec.com/worldwide/support/driverdetail.html?cat=%2fOperating+System%2fM...=aspi_v470.exe
Lastest says 4.70, but it installs mostly 4.60 -
Done that. The error msg at the bottom of the CDRDAO page under CD reader says, CDR Disable after ASPI drivers check. I used the (ASPICHK) and the only 2 things not installed were wowpost.exe and winasp.dll I have looked in the notes of vcd easy and it says that 90% of probs come from the CDRDAO section.
Go and get "ForceASPI" from http://www.doom9.org
This will install Adaptec ASPI v4.6. This definitely works on both Win9x/ME and WinXP well.
There have been many reports of problems with the newer Adaptec download.
If that fails, you can burn CUE/BIN images with CDRWin and also the newer versions of Nero. You can have a look at the guide at http://www.vcdeasy.org for more CUE/BIN burning options.
Regards.Michael Tam
w: Morsels of Evidence -
Originally Posted by vitualis
Originally Posted by KingJohn
Regards.Michael Tam
switches for install
FORCE This option allows the utility to force an upgrade whether the current
file installed on the operating system is older or a previous version.
SUB STATION ALPHA 4.08 - For 64 Bits Systems
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 23rd Oct 2021, 12:51 -
iTunes + Windows XP 64 bits, how?
By NormaJ in forum Software PlayingReplies: 11Last Post: 29th Dec 2010, 22:14 -
Vista 64 bits with 32 bits programs
By skaleton in forum ComputerReplies: 9Last Post: 15th May 2009, 11:41 -
SVCD2DVD crash on xp 64 bits
By alkirah in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Jan 2009, 08:17 -
Why would the bits/pixel drop?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 8th May 2007, 03:55
