Hi there guys...
I have the Matrox marvel G450eTV card and I just conected my VCR to the card to get some of my VHS tapes on the Hard Disk and then burn them onto (V)CD. The VCR is connected to the Composite Input of the VCR...
I captured a video sample to see how it works and test the different capturing codecs and I noticed some *MAJOR* differences...
First off, I captured the video from the PC\VCR Matrox Utility using YUY2 and 704x576 (25 fps) -I am in a PAL region. The quality was good. Here is a screenshot :
Then I used VirualDub to capture to Uncompressed AVI just to compare... So I chose video format --> YUY2 Full (704x576) and Compression ---> No Compression (YUY2). The result was this :
You can easily notice that the Matrox Capture has more "warm" colors than VirtualDub. What was surprising is that even when I used the HuffyUV through VDub, although the quality was not inferior to the Uncompressed AVI, the colors were not as warm as in the Matrox capture either...
1) Why is there such a difference in the colors ? Have any other matrox users noticed something similar ? Could it possibly be because of the Matrox YUY2 codec or is it because of the program I use to capture (PC-VCR and VDub respectively ?
2) Can anyone tell me what is this Flying Dutchman's YUY enabling utility which is needed for Matrox cards ? Can it improve the quality of capturing through VDub (i.e. make the colors "warmer" ? - see above)
3) Which of the two captures is the best in your opinion ? Keep in mind that I want to encode it into VCD or SVCD afterwards...
4) Since I will be encoding into PAL VCD later, which has a resolution of 352x288, is it wise to capture to 704x576 and then reside to VCD specs during the VCD encoding (TMPGEnc) or should I capture directly to 352x288 ? Which of those two methods will yield the best quality ?
Thanks in advance for any answers.
