hi!
i just got my PV233 card. I just recorded a one hour show which is in mpg format, using the capture card. But i saw that the captured video is jumpy!
not that jumpy, slightly jumpy. I thought maybe it will be okay after i burn it to vcd..but after i burn it to vcd. and play it in my vcd player, it is jerky and jumpy. I think is because the jumpy video that it used to be when it is in mpg format? Can anyone tell me how? when u all capture using pv233, will the video jumpy? there is no out of sync at all, only jumpy. I am currently using pentium 2 300mhz which is slow, thats y i bought this card. If want to upgrade it, i think for the time being, i am not able to do so, because never have enough money. Maybe anyone can give me suggestion on how to proper use of the card so that the captured mpg will not be jumpy? please anyone please help me!! My purpose for buying this card is to make those tv show to vcd. If the video i captured out is that jumpy condition, then i really have waste my money, because i am not able to get a good vcd..but jerky and jumpy. Please help me!!! Thanks alot!! to everyone for helping me..(say first keke)
if anyone have suggestion, if can maybe u can email to me too to black_box_sg@yahoo.com.sg
really want a help from u all! Thanks!!
also the bitrate which i used to capture is 1620...waiting for any helpful ppl to help me!
when i click the record buttom, the recording video is already slightly jumpy. after recording, i watch the video but it is jumpy, just like when i am recording the show, that jumpy come out. sorry if that my english is poor. dun really can say out wat i wan to say. but when i click the record buttom, the show is jumpy. I know the audio will be faster than the video when recording, saw many of u say that. But after recording, it never go out of sync, just jumpy. anyone help me to cure this!!!
Hi!
You don't say if you are trying to make VCD, SVCD, etc and if you are watching it on your PC or your TV. The bitrate you are using is not standard for VCD which is 1150. Try Skittelsen's registry settings at:
http://steve.kittelsen.com/pv231/
They also work with the PV233. Also, check your cables.
Good Luck! -
hi, i want to make vcd..=P. but i saw that if want to improve the mpg quality, then make the bitrate to 2000 above..right? anyway i am watching from my pc, and i wan to record directly from t he tuner. when i click the record buttom, the recording show is someting like a bit shaky, jumpy like that..let me know thx..the registry i already tried..=P thx~
It could be the cables you are using or the card is not firmly inserted in the slot. Try reinserting it or changing the slot. You might want to contact Skittelsen via e-mail:
skittelsen@yahoo.com
He's the Guru of PV231-233-256. -
i don't think is the cable problem because i can watch tv using tuner without any jumpy video or what..so i think is okay..only when i click record, the video become jumpy and jerk and flickering...=P, i try changing the slot or what..hopefully no problem then..previoulsy i also tried defrag my hardisk, but it makes no difference..thx for your help! hearing from u soon!
Jumpy video from Nikon d300s
By Owen1 in forum Newbie / General discussionsReplies: 19Last Post: 2nd Jun 2011, 04:27 -
Using S-Video To Capture Into Hauppauge 1600 TV Tuner Card
By waldodiodio in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2010, 18:49 -
Jumpy Video with DVD Flick
By matthewjohn23 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2008, 22:24 -
A good video capture tv tuner software for Ubuntu?
By Milardo in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2008, 16:05 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 18:09
