I recently burned a SVCD movie using BIN/CUE format using CDRWin. The Movie plays fine on my laptop but on my AD-1600 it begins to get distorted and choppy after about 5 minutes of playing...lots of ripping of the pixels, etc... it becomes totally unwatchable after about 7 or 8 minutes.
Anyone seen this before and have any ideas?
Remember, the movie plays beautifully on my laptop with no distortion, etc.
Thanks!
Matziq
BTW, I tried two movies....both burned in the same way using CDRWin in SVCD format...bin/cue.
Same issues.... -
If the movie can playing perfectly using the disc you burn on your computer than that means the problem is probably with the cd your using to burn the movie. I had the same problem when I change the brand of cd I was using. You can either try another brand or just burn at the slowest speed and it'll fix your problem.
Weird component problem with LG555 and Apex tv...
By dvd mon in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jan 2011, 15:40 -
Mencoder audio problem with MythTv and Hauppauge HVR 1600
By dabble1948 in forum Video ConversionReplies: 3Last Post: 17th Nov 2008, 15:48 -
Help with 1st up of Kiss DP-1600
By GJLCAP in forum Media Center PC / MediaCentersReplies: 1Last Post: 4th Aug 2008, 15:52 -
Streaming HVR-1600 Problems
By snipper_cr in forum Video Streaming DownloadingReplies: 0Last Post: 27th Jul 2008, 20:31 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39
