I have a few AVI (DivX) files that were created with 30.014 FPS and I am trying to find a simple way to change the FPS to 29.97 (standard NTSC VCD)! VirtualDub works great on the video portion, but the audio is out of sych by about 2-3 seconds by the end of the movie.
I am not greatly experienced with VirtualDub, so I am hoping it's just a setting I need to change.
Thanks for any help...
TigerVCD
By changing the framerate you are also changing the length of the movie slightly. Reducing FPS from 30.014 to 29.97 the movie will play slightly slower and so be a bit longer. The only solution to fixing the audio is to lengthen it to match the length of the video. Extract it to an uncompressed wav then use an audio editor to change the length to match that of the video. You can then re-multiplex with virtualdub or if you intend to encode to (S)VCD just use this new wav file as the audio input to your encoder.
Easy tool to change audio fps
By davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 05:23 -
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 15:09 -
best free tool to change fps of avi (and add new audio)
By thedarkness in forum Video ConversionReplies: 12Last Post: 22nd Nov 2010, 13:43 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 13:47
