I am trying to convert final fantasy avi to mpeg off tmpg it gets to 91% 99993/109531 frame. Is there anyway to cut that frame out. I have tryed to use divxfix and i rebuilt the index and it still did it. I am trying to rebuild it on virtual dub and it gives me a error when its a little more than halfway done.
please someone help me i want to watch this movie on my tv through my hollywood +
-mike
ps dont overlook this message help me
Results 1 to 11 of 11
also the error message virtualdub is giving me is "video source AVI [ICD Decompress] error unspecified: -100
please help me -
oh i just watched the part where it freezes and it freezes the movie for about 30 seconds and you have to go back to get video back!!!
I think the only way you can get around your problem is cutting the movie into 2 or more parts (depending on how many frames are corrupt). If you cut just before frame 99993 and build one file. Then cut again from lets say 99994 to the end. Encode the end part first, as you know the beginning is ok. If you get through it you can merge both parts together again.
load them in virtualdub, mark the section just before and after the corrupt frame as start/end points and hit 'del' on your keyboard. set both video and audio to "direct stream copy" and save the new .AVI
read the how to's on the left for more detailed editing info -
Make sure you have the DIVX codec 311 alpha installed. I used the method patrickm sugested and it works good.
HC enc: Your settings ?
By themaster1 in forum RestorationReplies: 6Last Post: 21st Oct 2011, 20:55 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
New Kiss DejaVu Enc released
By slmnow in forum Latest Video NewsReplies: 0Last Post: 20th May 2008, 12:08 -
I have flv files I'm trying to recode but they have an enc file.
By watusi512 in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 20:59 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23
