I ripped my copy of Reservoir Dogs, and all the files were under 4.5 gigs total. So i just opened Nero and tried to burn as a Video-DVD, the second it starts to burn, I get an error "Unexpected Exception" or something close to that. I don't know if it even wrote anything to the dvd-r. When I go the dvd in explorer, it says the capacity is 4.39 gigs, and my file is just under 4.2 (says explorer). WHen i open nero it sats my VIDEO_TS folder is 4.49 gigs. Then i try to burn it and get that error. Imusing a Pioneer 104 with firmware 1.20. I haven't installed any other drivers. Do I need to do so?
P.S. When i try using PrimoDVD, it says it couldn't find a writer to write to. Any ideas
Results 1 to 9 of 9
I got the same Pioneer 104/1.20firmware. Primo DVD couldn't find the writer. GET the "Recordnow Max " it has 30days full function trial, it's easy and work the first time for me.
My Nero5582 came with Pioneer 104, burn first 3 dvdr OK. Then I got another 80gb HD. NOW Nero not working anymore, when I try burning I get "communication error" after a week of rearranging 4 HD, 1 dvdrom, 2 burners, format & reinstalled WINXP for at leasst ten times I gave up!!
regards
Boonchai -
Sounds like a conflict with a resource somewhere. Where is the DVR-104 on your IDE channels and what else do you have on your IDE channels. (NOTE: Install the DVD recorder as the MASTER of IDE CHANNEL 2).
I took out nero, and got eh PX installer thing for PrimoDVD, and my DVD burned fine and worked my both my players.... : )
SLK001(MB?)
thanks for the suggestion. device manager ok, No IRQconflict on bios. I've tried using DVR-104 on primary master,secondary master, Ide 1 master, ide 2 master, latter 2 on Promise ultra 100tx2 ide controller still Nero not working with dvd burn
(cdr-rw still works) weird things is I did burn 3 dvdr ok before I add another HD. It's ok now, I just use RecordnowMax which took only half as long as Nero all with simulation and actual burns.
regards
Boonchai -
I used Nero 5.5.7.8 for 2 months with no issues. I was using the dvd video option which only showed up after installing 5.5.8 and then downgrading back to 5.5.7.8 because the newer version would not work. I tried upgrading to 5.5.8.2 and got the Unexpected Exception error also when trying dvd video option. I then went back to 5.5.7.8 and got the same error Unexpected Exception. I then tried the udf/iso option and it worked fine and the dvd played fine also. After 2 burns with udf/iso I tried dvd video again and surprisingly it worked. However after rebooting pc I get a new error using dvd video option, file allocation error or something to that effect. Then after several udf/iso burns it allows a dvd video burn, but after a reboot same file error. Does anybody know what is causing this?
I had the same problem with nero 5.5.8.2.
Download the latest nero 5.5.9.0 update, problem went away. Can write to DVD-R at 2x speed now.
Hung Bui
Have fun DVDing :P -
Just to add some more info to an old topic, I managed to get my Pioneer A04 working by changing the mode to PIO. In UDMA mode, Nero would get a communication error (with Pioneer on secondary channel as master...no slave). With PIO mode, everything worked fine. Change it under Device Manager, IDE Controllers, Secondary Controller (or Primary), Advanced Settings.
I also could not get Primo DVD to write to the Pioneer with Nero installed. Primo lists the A04, but doesn't let you select it as a writer. I guess that the 2 software don't get along well together.
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 10:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 02:11 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 01:01
