I am using Mediastudio 6.0 to make a home movie. I plan on burning this to DVD (new player HP dvd200i on order). I know MSP has a built in encoder, but I'm wondering if TMPGENC or other might be better for encoding the AVI file.
Question number 2 is, is it better to turn my DV file into an avi, and then compress to MPEG II, or straight from the DV file to MPEG II or does it matter?
Thanks for any help
I would use the Cinema Craft Encoder. Although the encoder costs 2000$, it's worth buying. The Quality is superb. You can use it with 720x576 at 2,4 MBit/s and you get perfect quality
1 . DV is seen by winDoze as an *.avi file
2. Not everyone has $2G buring a hole in their pocket saying buy CCE "buy CCE" ........ so that is not an option .....
except of course if you have an illegal copy !
3.Best option is to 'frameserve' using avisynth from MediaStudio to TMPGEnc
4. thru 999999. read the HOW TO section on how to frameserve and use TMPGEnc
I use TMPGEnc (as well as many other people here on the forum) and find its 2 pass VBR quality very acceptable. A fast CPU is suggested or a good nights sleep between encodes .... you decide
good luck
Create mpeg to VOB File
By bz186 in forum Authoring (DVD)Replies: 6Last Post: 1st Sep 2011, 21:45 -
Highest quality backups
By freewave in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2010, 20:32 -
IShowU Highest Quality Lowest File Size
By Jonahinthewhale in forum MacReplies: 9Last Post: 25th Sep 2009, 13:36 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 16:57 -
Best Quality Technique - Animiation, Print to Video?
By jherzog in forum Video ConversionReplies: 5Last Post: 11th Nov 2008, 15:02
