hello,
I have been editing with m2-edit pro, been able to get videos of non broken gops with the addition of 1 gop with only one frame in it (an I frame. I get the single gop with 1 I frame in it I believe because of editing out a closed gop sequence (commercial). This single gop dosn't bother me.
I can run my edited video threw mpeg_stat.exe and see my exact gop sequences that I have edited and they are correct.
BITSTREAM ORDER IBBPBBPBBPBBPBB
DISPLAY ORDER BBIBBPBBPBBPBBP
all correct.
My problem is when I encode them using panasonice mpeg encoder, the gops get all screwed up. I am encoding with a sequence of IBBPBBPBBPBBPBBI
I get a first gop sequence of
BITSTREAM ORDER IPBPBBPBBPBBPBB
DISPLAY ORDER IBPBBPBBPBBPBBP
then the gop's will be fine for 8 gop's and I will get an I frame in the 13th frame position. 5 gop's down from that a new I frame is inserted in the 10th frame position 9 frames away from the gops correct I frame.
Is this a problem with my encoder settings, or am I editing my gops in the wrong way?
I edit my videos in the display order, and when I have tride to edit in the bitstream order they where all messed up. I would get gops any where of 3 frames to 12 frames long, and would encode worse than my problem now. All I know is my edited videos before encoding are fine, but once they are encoded thing go wrong.
any help here would be greatly appreciated. thank you for your time
Results 1 to 1 of 1
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 10:16 -
USB Mpeg1 Hardware Encoder?
By leebo in forum Capturing and VCRReplies: 8Last Post: 9th Apr 2010, 23:32 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 14:40
