I'm having audio video sync trouble after editing mpeg1 file
The original capture file plays perfect, all I want to do is split the file in two for burning, or trim the front and end off.
I've tried tmpgenc12a & 12i using VCD, VBR and auto all create sync problems. I've also tried MyFlix and VCDCutter to edit but all create a sync problem.
I'm capturing using an ATI AIW radeon (P3 1Ghz) using the MMC_RegTool(from this site). I've captured using all combinations of VBR, CBR, I frames only and P B frames. All
sound perfect until I try to edit them.
I'm a newbie to this and I would greatly appreciate any help you can give me. I've tried everthing I can find on this site to try and solve my problem.
Results 1 to 1 of 1
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
sync trouble
By breeze9 in forum AudioReplies: 3Last Post: 29th Dec 2008, 14:13 -
Trouble Creating a on-screen tutorial for PC and Mac
By shmerls in forum Video ConversionReplies: 9Last Post: 26th Dec 2008, 18:33 -
MPEG1 SYNC error
By diginode in forum Authoring (DVD)Replies: 10Last Post: 2nd Aug 2007, 00:09 -
Magix Edit pro 12 trouble importing from DVD
By patsy in forum Newbie / General discussionsReplies: 0Last Post: 19th Jun 2007, 13:03
