What are the advantages of a capture card with a hardware Mpeg 2 encoder? I currently capture 720X480 avi uncompressed to an 80 GIG HD. I never capture mpegs. Is there anything I'm missing out on?
System Specs:WindowsXP Pro, AsusA7M266-D, Dual Athlon MP 1800+, 1 Gig of Samsung DDR 266Mhz Registered, 2 120Gig HD's ATA 100,1 40 Gig HD ATA 133 (System Drive Only), ATI All in Wonder 7500,550 Watt Antec PS,Full Tower Antec Case,2CDRoms
Pros
Speed - realtime compression
Small usage of disk space (especially compared to uncompressed)
Cons
quality
inflexible encoding
Hardware encoders can by definition only use single pass CBR or VBR encoding - obviously!
This single pass means that compared to almost any software encoder (with multiple passes) the quality will be less - more blocks
Inflexible encoding - you are limited to what the drivers provide, you may not want some of the options or bitrates
If your capturing uncompressed AVI and never capture mpeg then
no
you are probably not missing anything -
I couldn't agree more. Bought WinTV PVR for direct MPG2 encoding, and have found the results to be grossly disppointing. Now I use this card to capture AVIs with VirtualDUb, edit and frameserve to TMPGEnc. Takes alot longer, but at least the result is a good quality SVCD.
I don't agree. I bought the WIN PVR and have been very pleased with the results, although I capture at 6 mbs and make DVDs from the captures. I find that most of the people that don't like this card's MPEG quality are those using LOW capture rates(<3mbs, VCD kind of stuff). And, if you use DSCALER with this card the output is quite incredable for a $200 card. I have a 61" HDTV and can see every little flaw in bad video, yet this card has produced great results for me GIVEN HIGH BIT RATE CAPTURE.
A problem you have is the sheer size of HD that is required to capture AVI in real time (720 x 480 pixels/field x 3bytes/pixel (for real color) x 30field/sec x 3600 seconds/hour = 112GB per hour). At this rate, you are spitting stuff to the HD at a SUSTAINED 32 MByte/sec, which will tax most systems today. You can, of course, get superior results with this kind of resolution. However, the size of the HD is the main practicle limitation of this method.
I use a RealMagic DVR to capture MPEG2 at 9.5Mbps video and 384kbps audio, then transcode using CCE to more "normal" bit rates. Even so, an hour of capture at these bitrates is around 4GB. The results using my method is nothing less than supurb. I imagine that you would have results even better than mine. -
I have a Sigma(RealMagic) DVR hardware encoder and it's great. I mainly wanted the realtime encoding. When I capture from digital cable/satellite the quality is equal to what I can get from Tmpeg.
So, I haven't noticed a difference between the software encoder and hardware encoder, except the amazing time savings--which I the entire reason for purchasing a hardware encoder.
But others have stated that direct captures with this card aren't as good as tmpeg--all I can say to that is perhaps their source quality isn't the best and the wiring used isn't the greatest. I've presonally never had any problems.
I mean, what's the point of getting a great hardware encoder if you're gonnna use standard (read: cheap!) cables to deliver the source. After all you get what you pay for.
If you're happy with your current results and amount of time/effort necessary to get those results, then don't buy a hardware encoder. As all you'll really notice is time-savings.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
mpeg encoder for DSP
By mourya in forum ProgrammingReplies: 2Last Post: 31st Oct 2008, 12:28 -
Confused about Harware vs Software encoder
By marche in forum Capturing and VCRReplies: 6Last Post: 11th Oct 2008, 09:08 -
why do I have to disable harware acceleration half the times?
By majax79 in forum ComputerReplies: 15Last Post: 24th Sep 2007, 12:12 -
DV to MPEG2 using Mpeg encoder
By neftv in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 07:39
