  1. Trying to use TMPGEnc to convert an AVI into a MPG and squeeze onto a VCD. I followed the directions posted on VCDHELP and used the bitrate calculator and all seemed to go well. It converted and it burned onto one nonstandard vcd. but when I went ot play it on my Apex ad-1100w the picture was a mess! I had bands running accross the screen and it seemed to show the same picture on the left as it did on the right! Sound came out fine. I came soo close I know it must be some little thing I'm overlooking. Any ideas as to what it could be?
    Sep 2001
    Tasmania - Australia
    Dont worry about calculating the bitrate for a vcd just use the standard template and give it a go, you may have used too lower a rate to fully fill the picture maybe, what rate did you use?
    Welcome my son, welcome to the machine.
  3. Does it pays fine on your PC ?
    If yes try burning at lower speed (4x)
  4. Yes it does work on my PC and I set the audio to 128 and the rest tink to 1048. Also I downloaded the sample xVCD from this site and burned it the same ame it play fine in my DVD player.
    Now if I just use the standard template they give me the move will be too large for one disc correct?
    Jun 2001
    England
    Double pictures and lines across the screen!
    Sounds like you've got a sync issue with your video, DVD player or TV. Best thing to do is to take a 5 minute sample and encode with the standard VCD template for your region (PAL or NTSC). Once you get that working then start playing instandard bitrates and settings.
