Results 1 to 9 of 9
  1. Any ideas why, and what I should do now?
  2. Have you tried removing it?? I know silly question but nothing ventured, nothing gained.
  3. delete it, you don't need it.
  4. It just seemed odd because the guide on here showed the one they did had the file in that folder.
    I tried to burn it without that in, and it came up with an error straight away.....
  5. I guarantee you you don't need that file....... I use DVDMaestro to create my disks and burn them with Nero, and I just leave the .lay file out and it works just fine on a Pioneer 333 and an Apex 3201.
  6. Never had a problem leaving that out, among other files Nero found as not needed. What does that do anyway? Layer information? If so, since we are using single-layer disks, the file is useless anyway. At this point I don't know what I am talking about, I'll go now.
  7. Just curious.... what error does Nero give you with & without the *.lay file?
    May 2001
    If you are dragging files to NERO's VIDEO_TS directory using the DVD-Video template, don't worry about that file (it's not part of the DVD, just a file that Spruceup and Maestro create when they compile). I drag this file over all the time (and NERO always complains, but never drags it to the folder) and I have never had a problem.
  9. Originally Posted by dmonty
    This is from another thread I posted;
    "I've tried burning (test burn) in Prassi but got an error (re my other thread), and I've also now tried in Nero. It starts the test burn, but a little way through came up with this error:
    Pioneer DVD-RW DVR104
    Communication failure
    Simulation Failed 1x (1380 KB/s)
    What am I doing wrong? I ripped the dvd in SmartRipper, authored in Spruce Up, and have select DVD-video with the same settings as on the Nero/DVD guide on this site, and thrown the files into the VIDEO_TS folder.
    I have burned a data dvd-rw ok (just a load on mp3's as a test to make sure the drive works) and that was OK. "
    I can't work out which stage of the proceedings I'm doing something wrong....
