how do i convert
rush hour 2 - 1 hour and 30 minutes - 733 size MB
To a video cd.
Programs i try:
TMPGEnc but it made it to 2.5GB, then a downloaded a template kvcd, and it made it, to 1.3GB, but with no sound,. to big for a cd. a 80 minute cd.
xing encoder, it stops after 4 minutes, it doesn't do the whole movie.
lsx-mpg encoder doesn't take it, a problem with the audio.
is there any way that i can put this movie on a 80 min cd, eny quality.
thanks
You can with KVCD, but not if your source is a DivxOriginally Posted by joelbenitez
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
You will have to drop down sound to 128kbps and reduce bit rate to 800-850 to be able to fit it on 1 CD( Bad quality). The reason why you dont get sound from your VCD is that your original DIVIX file has to be re-encoded with Virtual dub(audio only) and than use TMPGenc to convert to VCD. In my opinion u r better off, using 2 CD instead of one. Increase bitrate to 2000kbps and get excellent picture quality.
Cough..Originally Posted by alexb
Well. 128K? 800-850? 1 CD bad quality?
Here's a 30 second sample at 160Khz audio. What you'll see did fit in ONE CD. Complete 135 minute movie.
http://ns1.shidima.com/kwag/sample5.mpg
i am going to try 128 b, for the sound, and 800 bitrate for the video, but if that don't work then ain't no other way to put it on a vcd with out having to use two cd's.
http://www.kvcd.net/forum/viewtopic.php?t=375Originally Posted by joelbenitez
Saludos and Have fun!,
i try the 800 bitrate for video, and 128 for sound, and it looks alright, but
is a 2GB 493MB, and it goes for 4 hours and 30 minutes, and the movie is only 1 hour and 30 minutes. thats a whole different problem,
how can i fix this one,
the movie is 1 hour and 30 mins,
when finish encoded with 800 bitrate, 128 bit sound, it goes for
4 hours 30mins. and is 2GB and 493MB
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
