I tried to use VCDEasy, but it just won't work, I get an error message saying "there's no CD-RW drive or ASPI layer problem"
So I must use my regular burning program, Padus Discjuggler.
The problem is, the VCD file (i downloaded it with eDonkey2000), is way too big to fit in a CDR, it has 768MB, how can this be a VCD file, if the CD has only 700MB of space???????
Also, what setting should I set in Discjuggler to burn the VCD?
Thanks in advance!!!!!
http://www.padus.com/support/manuals/discjuggler/cdjhtml/03_Tasks/Index.htm
I'm puzzled with this one, Juggler has never been able to make VCD's , Looking at Version 4, I cannot see anything related to VCD's
Apart from
Mode 2 CD-ROM XA:
This is the recommended format for multimedia applications like VideoCD, PhotoCD or
when multisession is required like in CD+ or EnhancedCD. "Mode 2 CD-ROM XA" is the
default selection.
Are you using VCD easy to make the VCD, then juggler to burn the data ?, if so then Mode 2 is what you want.
As for file size, that mpeg should fit, if your not adding any PC autorun or CDI softwear. However TMPGEnc can split mpegs -
See, this is what I don`t understand.
How can it fit if it has more than 700MB??????? -
There is a technical answer relating to error correction, but trust me - it can. With SVCD 790MB mpg will fit on a a 700MB CD! 8)
However, Padus Discjuggler is a wonderful piece of software, but it does not burn VCDs. Well, I don't have version 4, but none of the earlier versions did.
Get a copy of Nero www.ahead.de if VCDEasy causes problems. I would not recommend Roxio products like Easy CD Creator, personally. 8)
Burning mixed/split mono VCDs
By ministry88 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 21st Jul 2011, 12:04 -
Nedd some advicese before buing a Camcorder?
By john7911 in forum Newbie / General discussionsReplies: 8Last Post: 22nd Nov 2010, 04:49 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
