i have a .bin/.cue file but i can't get the .cue file going i get and error NO TRACKS WERE DEFINED IN CUE SHEET
so would i be able to burn the bin file?
thanks
Use Nero, select file > burn image. Select the .bin file. Is it a mpg, select MODE2.
if the .bin file is supposed to be a (s)vcd, I'd suggest you rebuild the image...
e.g. with vcdimager:
vcdxrip -b lonely.bin
vcdxbuild video.xml
this get's you a fresh videocd.bin and videocd.cue
(_don't_ use the videocd.cue for the originial bin-image, use the newly created one instead)
this process will rip all items from that bin, and leave you with mpeg files and a videocd.xml description, which is used by vcdxbuild to create the image...
if you burn your .bin image as one big track, you may end up with a wrong TOC, this may or may not cause problems with playback... -
if you can't get the cue going, most likely you need to open it up in note pad and make sure you have the right path, for example "C:\WINDOWS\Desktop\SavingPrivateRyanDisk1"
I haven't ever had a cue that I couldn't use. -
ditch the cue and convert the bin to mpg with vcdgeargui.exe, available under "tools".
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
