I've searched through athe archives but can't find anything on this.
AVI is beautiful (ATI owner that will not use their cr*p) and when passed through a SVCD NTSC template the A/V sync is out within minutes.
Never had that problem before (as if it makes a diff), besides using 10 other programs to "fix" the problem, anyone know what the problem IS?
I've had this problem occasionally. Try extracting the audio as a wav file first. Then encode in TMPGEnc using the wav file for the audio portion. If that doesn't work, check settings in TMPGEnc to make sure frame rates match, etc.
Try using AVI_IO or VirtualDub for captures. I don't have any trouble with sync using these programmes.
I agree with the ATI crap! I have ATI AIW Radeon & the software bundled with it was total garbage.
If this doesn't help, post again.
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
Raw DV to AVI style DV without transcoding?
By Daz_Genetic in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Dec 2010, 23:25 -
How to extract raw viedo from an AVI
By Kunioh in forum Video ConversionReplies: 5Last Post: 10th Oct 2008, 07:09 -
CassetteDV - Input from raw dv avi files?
By ICTag in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Nov 2007, 05:06 -
Raw H264 to AVI Under OS X?!?!?
By RAILheadDesign.com in forum MacReplies: 4Last Post: 1st Jun 2007, 11:29
