  1. help!
    i d/l the godfather 1-3 besides some other movies some time ago. i tried to burn the plain avi but it always stoped at 20% with some error like "padding blocks added" (with cd mate....tried 3 other progs too....).
    i thought it should work this way because its data like anything else so it could be burnt on cd like anything else...
    now i tried to create a svcd out of it with tmpeg but in the wizard at step 4 it says the output file would be 5gigs....
    i can watch the avis as usual on my hd, without any errors. any suggestions? i talked to other guys that d/l the same version (from SR) and they had no troubles.
    bye, sepp
  2. Banned
    Jun 2001
    UK
    1, load AVI into Vdub and scan for bad frames.
    Video > Scan video stream for errors
    1b If it finds bad frames,
    Video >Direct Stream Copy and
    Audio > Direct Stream Copy and
    SAVE AS, save out another copy of AVI
    Better still use "vdub-mp3-freeze.exe" logs junk frames
    Better still try TMPGEnc-2.55.38.142 converts junk frames
