  1. Hi
    I try watching a VCD using CDRW but it does not work, saying no disc.
    I try using 6 different brands of CDRW, all don't work.
    Can someone advice why? Thanks !!
    My VCD player is Toshima VCD-330.
  2. Look to the left and select the DVD Players listings, look for your model, I just found it and it appesrs yours will not accept CD-R or CD-RW type disk.
    Aloha
    Bud
  3. Hi
    Thanks , i have tried to search for it eariler, but cannot find it. And i still cannot find it now. Mabe i use a wrong searching method?
    Mind showing me the URL? appreciate that a lot!! Thanks !!
  4. The one I found indicated a Toshiba SDK 330, just do a search on Toshiba and scroll down, go the next page and you should see it down a the bottom.
    Aloha
    Bud
  5. Hi
    Thanks , but mine is a Toshima VCD-330 ,not a Toshiba SDK 330. Or are they the same? Pls advice again.
    But just curious, in general, can VCD players play movies burned in CDRW?
    A friend advise me " cdrw doesn't END the burning sesion ! , unless is specified that your vcd player can play CDRW ! "
    is the above true?
  6. It appears to me that you have a DVD Player almost like the Toshiba, I just don't think yours will play CD-r or CD-RW type Cd's. See if you can get one of your bud's to try to play the CD-R on one of there system just to see if they can play back. If not I can't help beyond suggesting you try to get another updated payer.
    Aloha
    Bud
