When using dvd2svcd I get this problem:
BBmpeg crashs when it comes to complete the file. It trys to join them but when it comes to start joing file 2 it crasges!! Anybody had the same problem?
I would search doom9 but my computer can't acces his fouroum will somebody do it for me?
Baker
seems to be a common problem with 1.0.3 pre 24 ...1.0.9 build 2 and pre22 seem immune to bbmpeg crashes.
you sure you can't access the forums on doom9?
that's weird
http://forum.doom9.org -
Well I really can't access the fouroms. I never could.they come up and all but the names of the posts are missing! So I am unable to access them.
I was just about to give up on dvd2svcd and try dvdx with the cinema caft plug-in, but now if this is a common problem, I might be lured baqck.
baker
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 23rd Apr 2011, 00:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 06:45 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48
