Hey guys, another little problem which leeds me to HaraKiri...
The MPG2 file from the CD seems to be broken. Originally it have to be about 730 MB after reading out the SVCD with VCDGear 3.07beta (Using MPEG -> MPEG) but at 350MB the program rewrites the MPG header and stopps. The file is only about 350MB and broken...
Hmm, then the multiplexing with another audio stream fails. Not really failing because the video stream is already broken.
How can i read a functioning stream out of the CD or better asked whats the problem?
Who knows a possible answer to solve this prob...
Please, HaraKiri is near...
Greets, zedriq
Please...
I need to know which program i have to use to get the video stream fixed!?? -
this probalbly wont work, but why not try using isobuster to extract the contents of the disc?
I already tested cdMAGE (program like isobuster), but this didnīt work well because it read out the whole stream, but then - when multiplexing - TMPG only writes 350MB again...Originally Posted by boss
plz more ideas...
But i will now test isobuster first... -
See if you can copy the mpg from the SVCD to your HD. Then try first with TMPGenc to demultiplex. Then try to multiplex. You will probably get errors at the multiplex stage. If you do, then try running it through DVD2AVI, as per the guide on this site about converting SVCD to VCD. Then encode the audio and video streams to SVCD again. This is not ideal, but the quality should be pretty close to the original.
Hmm, seemes to be a very heavy work for that...Maybe i wil d/l the movie in wanted language...
Demultiplexing doesnīt work, too... -
If demultiplexing won't work, your only option is to use DVD2AVI IMO.
The Film Machine Problem... MULTIPLEXING FREEZE
By supermannnnn in forum Video ConversionReplies: 3Last Post: 16th Dec 2012, 12:51 -
DVD rewriting with menus etc
By murihikukid in forum Authoring (DVD)Replies: 1Last Post: 10th Sep 2011, 00:37 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 10:16 -
Rewriting header
By DVDONE in forum Video ConversionReplies: 10Last Post: 17th May 2010, 16:11 -
Desktop icons constantly rewriting
By cal_tony in forum ComputerReplies: 8Last Post: 23rd Apr 2008, 17:34
