    May 2002
    MONTREAL - CANADA
    I am working with dvd2svcd with 2 audio chanels . the movie is 2:10 and i have made 5 images mpeg ( 655 and 690 mx). And after i am working with ULEAD MOVIE FACTORY. 700 mb is too big to work with it ??????
    -some person say to try overburn ????? ulead does not accept bigger size ?? PLEASE could some body explain it to me.
    Is the speed of the burner (faster or slower) changes something for the making of the video?
    Mar 2002
    chicago
    your question is a little confusing(to me, anyway)...
    are you saying that a 700MB mpeg is too big to burn as a vcd/svcd?
    if your using 80 minute CDs, then no, it's not too big at all!
    VCDs are burned in mode 2--search for this and you'll understand--therefore, there's enough room on a 700MB disc for 800 mb of mode 2 data. use VCDeasy to make an image of the disc, and then burn the image using whatever burning software you like. that should do the trick.
    what are you askin' me for...
    I'm an idiot!
  3. ! don't overburn if you don't know if your burner can do it. 2 an svcd mpeg can be almost 800 meg without overburning, i can't say that i know the limitations of ulead tho.... you could always make 2 mpegs of say 390 or so and then stick them back together with tmpgenc...
    #videohelp on dalnet!
