hi all..
nice greetings from vienna
yes i have a big problem with burning VCDs with my old 8x plextor burner (scsi)...
every VCD i have burned isnt playable by my standalone DVD player Daewoo 8000F.. which i buyed in a media markt in vienna..
so now my question.. is it possible that my DVD player cant read CD-R discs which are burned with a CD-R only writer ??
becaus if i burn the same discs on the cd-rw burner of my fater or girldfriend the discs worked very good..
i also tested low speed (4x) but there is the same problem, bad picture, big colour errors and so on.. and often the DVD player stops working![]()
Check the DVD compatibility list to see what you player supports. My guess is that it doesn't officially support CDR/RW but will accept the CDRW. My Panasonic RV31 does the same thing. Doesn't mind the CDRW but gaffs on any CDR.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
yes thx.. thats the same what i think about the problem..
now i burn my vcds on the cd-rw writher of my father .. and everyone works fine on the DVD player..
Writer not burning at 16x like it should
By championjosh in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Mar 2008, 02:59 -
Writer burning discs erratically
By uNderdog_101 in forum DVD & Blu-ray WritersReplies: 11Last Post: 28th Nov 2007, 14:08 -
Problem with burning using my LG writer won't go away
By pwil30 in forum DVD & Blu-ray WritersReplies: 7Last Post: 16th Jul 2007, 10:12 -
problem with dvd writer
By daniel1800 in forum DVD & Blu-ray WritersReplies: 9Last Post: 7th Jul 2007, 17:47 -
dvd writer problem
By ellabbs in forum Authoring (DVD)Replies: 1Last Post: 6th May 2007, 03:47
