  1. I need help. I tried following the steps to making my d/l movies to mpeg files so that i can watch them on my home dvd, but i am having trouble d/l the vcdeasy, the web site is having problems and i am not able to d/l that. my other comment is that does the encoding or whatever i am doing on the tmpge thingy take sooo long. the thing that is playing the movie now is that encoding?
  2. for VCD easy, goto www.google.com and search for vcdeasy and you are surely to find another download site.
    video encoding is a very time consuming and processor dependant process. it does take time and it will max out your processor.
  3. Try out TMPGEnc - it really is the best encoder out there. Make sure you have selected the source aspect ratio as "1:1 VGA" and in Advanced options set the aspect to "Keep aspect ratio 2". You'll find all these out if you look around in the wizard.
    Yes, encoding takes ages - I leave my computer on when I go to bed as it usually takes it about 8 hours for every hour of movie. Having said that, I am a perfectionist....
    Good luck!
    CobraDMX
  4. CobraDMx,
    it takes you 8 hours to encode!?how big is the file when you get done? is it like 1.5 Gbs?
  5. No, it's standard 1150kbps MPEG-1 for VCD. It takes ages because I have my motion search precision maxed out, and I use all available filters to get the best I can out of that small bitrate.
    Should I be getting faster speeds, even with these filters? I am running a P4 1.5GHz with 512MB RAM.
    BTW, I am a perfectionist
    CobraDMX
  6. PS - That's 8 hours per hour of input movie. So, a two hour film I just did took me 16-and-a-bit hours.
