When encoding the dvd files in tmpgenc, it sometimes produces .mpg files that are too large to put on a cd. This seems to occur when I use 2 or more cds for the movie. The first cd is always ok, but the second one comes out over the 800 mb limit. I have tried changing the bitrate settings in dvd2svcd, but it doesnt seem to work. Anyone with a suggestion how to fix?
I usually choose 3 cds if the movie is longer than 1:50 . in the bitrate tab I have not had the problem since. I know there is a better way, but this works for me. I have not had this prob. with cce 2.50 yet
dtoolmanWhere the heart is is where the soul goes, when it is all over. -
Had the same problem........just used overburn in nero as it was only about 5MB to big. You could also reduce the CD size by 5-10 mbs in the bitrate tab if your burner wont overburn.
cheers
Looking for a hosting site to send or store a large size of .MTS video file
By coody in forum Video Streaming DownloadingReplies: 5Last Post: 25th Apr 2011, 16:08 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
dvd help .size.file to large shouldnt be.
By larebow in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2009, 01:08 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48
