I was trying to combine my video (mpg) file with my music (mp3) files .. but when I play it ... some part of it has a static sound ... how can I fix that?
I try using the "noise reduction" option in TMPGEnc ... but then it entirely delete the sound of the file ...
help help .... =![]()
thanks.
Hi Lilt,
If You're trying to convert 48 kHz sampled sound to be used in you're
VCD it is known that TMPGEnc does not like that, so convert your audio
first down to 44 kHz using for example Virtualdub.
File > open video file, audio > full processing mode, audio >conversion, and select 44kHz and High quality. Then file save wave. This will creat a hughe wave file (1 Gb for 120 min) but the audio will have the right sample rate.
Feed this file to Tmpgenc.
good luck,
Borgster.
Hi Borgster
But the mp3 file I used is in 41MHz though ...
regardless ... thanks for the suggestion ... I will try doing that if the same problem persist ...
lilt -
Hi Lilt,
try merging the uncompresses wave at 44KHz (large file), Tmpgenc works fine with me that way.
greetz,
Borgster.
P.S. Let me know if it worked!
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 21:20 -
audio lag in .mov to .flv converted files
By french-petzouille in forum ffmpegX general discussionReplies: 5Last Post: 3rd Mar 2012, 13:05 -
VOB2MPG (converted MPG file has no audio!)
By sonicdeth in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 5th Jan 2010, 20:23 -
No audio with converted video files
By TomLJ in forum Video ConversionReplies: 10Last Post: 7th Oct 2009, 15:47 -
Audio becomes out of sync when converted (transcoded?) from .vob files
By Neptuna_Fish in forum Newbie / General discussionsReplies: 12Last Post: 21st Aug 2007, 20:39
