This may be a dumb question, but the information I had located (somewhere) apparently is not accurate. I am trying to calculate storage requirements for real time DV capturing. I would like to compare numbers for raw vs hardware encoded video as well.
Someplace I had located information that raw video was 100mb per minute. Today a guy helped me transfer 10min of video to disk and it was 2.4GB! This is more than 200mb per minute.
I want to capture the video for full screen (PC) playback. Does that make a huge difference in the raw video file sizes?
(when I saw raw files, I am talking immediately captured video stored as an AVI file).
These numbers are important as I am looking at hours and hours of video needing captured. If I use a card to encode to MPG-2 in real time, what type of storage requirements am I looking at? (MB per minute?)
Thank you.
2.4Gb for 10 minutes sounds like it is only compressd using huffyuv codec, a high quality, lossless codec that gives storage around there (normally I would of expected a bit smaller - I have a 15 minute video at about 2.1Gb at quarter frame 352x288).
Your size greatly increases depending on resolution (ie about 4x the above numbers for for full frame) -
This may come as a shock to some ....
The CCIR 601 (NTSC) data rate is ~165 Mbps.
http://www.cs.sfu.ca/undergrad/CourseMaterials/CMPT479/material/notes/Chap3/Chap3.4/Chap3.4.html
Big Eh !!
DV is a compressed codec with ~3.7 Mb/s = ~220 per minute. That 10 minutes was most likely DV video
It is only possible to capture 'full' screen for a computer if it is running a 640*480 screen resolution since DV is 720*480 (NTSC spec)
Since most people these days run 1024*748 the video will require resizing.
Difference in video 'sizes' has nothing to do with screen size per say but everything to do with BITRATE (datarate)
Very Mixed Requirements
By juliam in forum Newbie / General discussionsReplies: 7Last Post: 5th Jul 2011, 00:15 -
What's the computer requirements?
By Tomday in forum EditingReplies: 6Last Post: 26th Apr 2010, 08:26 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 12:15 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 05:32 -
HD system requirements
By kippard in forum Newbie / General discussionsReplies: 25Last Post: 20th Jun 2007, 03:05
