I messed up and tried it and now istuck with it?
is theer a program that well change it to a mpeg?
Please help!!
Results 1 to 11 of 11
Virtualdub v1.3 will open asf files and so will TMPGEnc v2.0
Big_Jit -
Install the Nimo Codec Pack and reboot! Then try it... Make sure that you're using Virtualdub v1.3 or TMPGEnc v2.0
Big_Jit -
nimo is 0kb and wheer can I find version 2?
All i see is new ones of tmpg -
Most of the time I convert .wmv files using TMPGEnc. Just open the file by selecting 'all files' in the open dialogue and it will normally convert it to mpg fine.
You can also use GraphEdit but it is a bit cumbersome. -
Please not that any version of TMPGEnc works, I recently did one using 2.55 and have done ones with considerably earlier version.s
The reason that i stress version 2.0 is because alot of people have had problems with tmpgenc locking up after about 10 minutes of encoding but version 2.0 has worked every time...
Big_Jit -
When I have a WMV file that uses the nasty WMV1 or WMV2 codecs I have had success with this guide: http://www.divx-digest.com/articles/asf_wmv2avi_mpg.html
Panasonic DMR-ES45VS, keep those discs a burnin' -
well the quality may not be the best in the world, and its a quick shot, but just drag and drop the wmv file into nero and let it convert it for you. I sucessfully did a couple of wmvs that way and it worked fine. Hey....its worth a shot......
Convert mpeg-2 to wmv
By king71 in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 03:26 -
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
Deinterlacing when going from MPEG-2 to WMV
By courtneye in forum Video ConversionReplies: 1Last Post: 9th Jul 2010, 09:24 -
WMV vs. MPEG compression artifacts?
By smexxy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 23:33 -
WMV to MPEG gives error
By tommm in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:46
