Hello all,
I'm making a backup of a DVD and I have a really stupid audio question. I am using DVD2AVI and if I choose "Decode" audio I get a 1.7GB WAV file and if I choose "Demux" I get a 500MB AC3 file. My question is: Which size will it actually be when I burn to my DVD-R? I ask because I want to make sure that I make my average video bit rate is as high as it can be without going over.
I will be using either DVDit or DVD Workshop.
Thanks for your help!!
yes, really is a stupid question...it will e the size of whichever audio file you choose to use. Personally I would go AC3 becuase its dolby digital and smaller.
Yes, a really, really stupid question (just kidding)! What you really should be asking, is whether or not your authoring programs can import an .AC3 file. DVDit-PE can... I don't know about DVDWS.
Basically, the two files are the same (audio wise). So, you tell us, which one should you use if you want to maintain maximum bitrates? -
But this AC3 file is most likeley DD 5.1 and AFAIK Dvdit only supports 2channel (stereo) AC3 at best, so it will probably spend ages transcoding it for you. In that respect, give it the uncompressed wav file and let it transcode that, should be a bit quicker!What you really should be asking, is whether or not your authoring programs can import an .AC3 file. DVDit-PE can...
I believe Spruce will import DD 5.1 AC3 files.
Sorry to ask a stupid question, but WHAT IS A MEDIA CENTER?
By jbitakis in forum Media Center PC / MediaCentersReplies: 1Last Post: 11th Nov 2011, 23:18 -
Stupid question about BD50 to BD25
By timmus in forum Blu-ray RippingReplies: 2Last Post: 11th Sep 2010, 21:26 -
Stupid Divx HD on PC Question
By belfastrab in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2009, 01:18 -
Probably a stupid question, BUT...
By HmNtr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Dec 2008, 13:22 -
probably stupid Avisynth filter question
By ecc in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 10:21
