I'm new, so go easy. I just downloaded a movie (first one), and in my attempt to burn it VCD with Nero, I cannot link the cue file with the bin file. I may have heinously screwed up somehow, because although the file is exactly where it should be, it is NOT a bin file. It's a .part file.
My question: what do I need to do with this .part file in order to be able to burn it? Is a conversion possible? If I need to just dump it all and start over, I will. But it'll kinda bum me out.
This question is probably dumb enough that I'm making someone's ears ring with it, but I've searched this site up & down with no luck.
Any suggestions?![]()
nero is notoriously bad with bins and cues.. try using fireburner.
www.fireburner.com
just open up fireburner and select 'file > load tracks' then select your bin file. it should load fine. you might need to re-name your file so it has an .iso extension instead of .bin ..
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Thanks for the tip, Geek Rock. But, no go.
Somehow, I either converted the .bin file to a .part file when I was goofing with Isobuster or something.
What the heck is a .part file anyway?? Where the .bin should be I've got:
1.part
1.part.met
2.part
2.part.met
Ive checked the properties of the .part files, and they are in fact of the exact same size the .bin is supposed to be. I thought that maybe it was for "partial" but the files are completed.
I'm stumped.Always do sober what you said you'd do drunk.
That will teach you to keep your mouth shut. -
sounds like you need to take yourself on over to the edonkey forum to figure your problem out.
if the files are still part then why do you think you finished downloading??? -
go to sharereactor.com and look through their newbie guide--it will explain how and why you sometimes will end up downloading more than the file is supposed to contain before you are actually finished downloading
what are you askin' me for...
I'm an idiot! -
Fantom Lord- ya nailed it dude. The first .bin file ended up larger than expected, and simply wasn't finished.
Looks like I posted in the right forum after all (Newbie.)
Thanks to all for the suggestions & help.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
Help a newbie with BR burning... please.... :)
By mefistofel_666 in forum DVD & Blu-ray WritersReplies: 8Last Post: 3rd Dec 2009, 17:11 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43
