Hello!
Wich DVD author program supports 5.1 ac3??
DVDit PE does not seem to do the trick.. !? (Only 2channnels)
Steve
SpruceUp can do it. The problem is finding a 'working' copy. Try seaching via KazZa, E-Donkey, Bearshare or another peer2peer app.
I have Spruceup, but I always end up with a bluescreen everytime i use my DVDrom when Spruce is installed. (Doesn't help to uninstall either.)
(Format c: is the only solution it seems... ) -
I think spruce requires that ASPI be installed. Have you tried installing/reinstalling you ASPI driver?
D -
Reinstalling the latest ASPI would'nt help.
Installing XP did the trick though.
What seems to be the problem with ME then? Any ideas? -
I'm trying to stop myself from answering this question with the arbitrary," IT SUCKS", response. In an effort to maintain my civility I'll just say this. Windows ME was rushed to market. As a result it suffered considerably from crashes, hangs, and hardware compatibility issues. In short ME should have been a beta.
XP is the first OS from MS that I have used that has impressed me on its first release. -
Me's weaknesses is not a strange thing. In fact, you should be aware of it, as it is a home OS, built around the win95/98 engine.
XP's advantage is it's built upon WinNT's stronger stacks, protected memory space, services, demons, emergency subrutines and a long list.
XP Pro is just as strong as win 2000 and NT, while adding a nicer GUI, and a better PNP support.
Me's never been intended for professional use. Period.In this industry, Sadly, The future was yesterday.
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
Long silence in ac3 is mysteriously shortened when I author
By Genaugmen in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2010, 16:47 -
DVD player that supports GMC?
By perdomot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Nov 2007, 17:38 -
Wich freeware encoder is best with DVD Rebuilder?
By julitomg in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 22:10 -
I have a Denon DVD 3800, wich software and dvd-media do you use
By xsienix in forum DVD & Blu-ray PlayersReplies: 10Last Post: 25th May 2007, 15:10
