Hi all,
I have a question about installing chapters on my SVCD backups using
chapter Xtractor and VCDeasy. I break the movie into two parts for
two discs. However, the break isn't always near a chapter. When I do
the chapters for the second disc, should I make the first chapter after
the break the start offset or should I make the break the start offset ?
ie: Movie runs 2hrs and I break into two 1hr parts.
Closest chapters are say 55:10 and 1:04:00
Do I make the start offset of the second disc at 1:04:00
(meaning next chapt after the last one put on) or do I make
it 1hr, followed by the rest of the chapter stuff.
Weasyl (sorry if I am unclear, I will try and clarify, just tell me)
Yes - In this example, this will give you a chapter break 4 minutes into the second disc, which is what you want.Originally Posted by weasyl
I typically try to split the mpegs at the chapter break closest to the halfway point - because I don't like to switch the disc in the middle of a scene. But that's just my preference - it is a little more work.
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 14:13 -
good question about dvd chapters and workflow
By YOURCONNEXX in forum Authoring (DVD)Replies: 7Last Post: 18th Feb 2011, 17:32 -
Newbie question: menu and chapters
By cheerful in forum Authoring (Blu-ray)Replies: 0Last Post: 19th Dec 2010, 23:17 -
Chapters in ConvertXtoDVD. Have a question.
By KTV86 in forum Authoring (DVD)Replies: 8Last Post: 15th Oct 2009, 04:35 -
DVD Lab Pro chapters question
By jesterhud in forum Authoring (DVD)Replies: 9Last Post: 23rd Aug 2007, 18:06
