  1. ok this is what is going on i have a video were the subs are supposed to start at 9:20 lets say but the subs start at 18:20 how can i match them together so the subs are in line with the video please tell or tell me what guide to use thanx
    Feb 2001
    Berlin, Germany
    Which subtitle format, video and CD format you are talking about?
    Also please tell us, which tools you use and some source file specs. I am pretty sure then anyone is able to help.
  3. the video is 616 x 424 in size, 16:9 pal, 25 fps, constant bitrate 4000
    the d2v is 16:9 616 x 424 24fps
    the subs are .srt and .ssa
    see the subs start at :18 they should start at :09
    i use tpmgenc, virtual-dub, dvd2avi, subrip and many others
    Feb 2001
    Berlin, Germany
    I assume the source is MPEG-2, is it? Stange resolution btw. Check the dvd2avi settings. If the source is PAL, you have to check "field operation: none". Maybe that solves the problem. If not, I suggest to load the *.ssa script and the audio track into SubStationAlpha and compare resp. adjust the time stamps if necessary.
  5. the normal resolution is 720 x 480
    and how do you do time stamp
    i am doing this movie versus and i want to do it right
