  1. Buried 20 pages deep in another thread, someone mentioned that they got 'better' results when going from DivX to VCD/SVCD/KVCD by first uncompressing the DivX file in VirtualDub first. Has anyone tried this, and does it really make a difference? It seems like this should have no effect, because you can't regain the info that was lost in the original divx compression... any info appreciated.
    May 2002
    Rainy City, England
    You decompress the audio to wav. if you don't you will very likely get sync problems with DivX that use variable bitrate mp3.
    Feb 2001
    Berlin, Germany
    Some audio encoders require uncompressed audio. Decompressing the video is useless. You have answered the question yourself.
  4. Thanks, turns out I slightly misunderstood what the other people had mentioned. Turns out I can use 'ffdshow' in place of the standard DivX codecs, and do some post-processing of the original DivX file before passing it into TMPGEnc. Looking at ffdshow, it even allows for resize/sharpen/crop/deblock, etc. I don't know how these filters compare to AviSynth's filters, so I'll give them a shot.
